Well I have figured out that really good quality workman ship is hard to come by . We developed a oil leak at the pto on the tranny and so the people that put the bed on said to have it checked out and then call then so I did that . Weds took truck to the shop and they called back and said that they retightend bolts and cleaned it off really good and would check it today to see if it was still dripping . About 11:30 the repair shop calls me and says that they needed to pull the pto as it is still dripping so they ddi and the idots at the place that put the bed on the truck did not get all the old gasket off from around the bolt holes plus they had like a .050 gasket on it which was way too thick and last but least the freaking drain plug in the bopttom of the tranny was finger tight :Banghead WILL NOT BE BACK TO THE PLACE I BOUGHT THIS BED FROM FOR SURE!!! Should be able to pick truck up Fri .And if the place we are hauling from has dried out and the dumping site is dry then we will work again Sat :notworthy Thank goodness . have a great day and for lettting me vent my anger .twj
Man that stinks. You really do have to watch where you buy from and read every word of their warranty. Hope that it all worked out!
