Hello, I am new to the forum and have a 1999 year serial number 11263. When loading on a trailer and hitting a slippery spot on the deck or ice on the ground the right rear tire spins out and the rest dont move. Seems to run fine on mud and soft ground. Speed seems to be find in 2wd and 4wd. All other things seem to be fine.
I was told this was normal, but in looking at the hydraulic schematics for the machine it appears to me that more than one wheel should spin because the hydraulic flow is split between the wheels, unless a check valve or relief valve is not working. The same wheel spins out in forward and reverse, as I tried turning the lift around to load. All the wheels are are contacting the ground.
Just wondering what to check first, or if this is indeed normal.
Thanks
Thanks
