Just bought a 2002 tmz 34,wasn`t running,was told it needed platform controller membrane pad to get it going,I replced that and put in new batteries,switched it on,it has man outriggers,lights on all 4 wouldn`t come on so I cleaned the switces on the legs and got the lights to come on when level,but I can`t get anything to work. So I got the service manual,found the trouble shooting sequence for the pump,checked for 24 volts going from the cpu to the motor controller #1 terminal,none,checked for 5 v going from cpu to motor controller#3 terminal,none. I aiso checked the controller trouble shoot sequence ,checked for 5v going to the key switch junction,book says 5v there but getting 24v there,no difference in trying platform controls or ground conrols,the only thing that works are the level interlock lights and the horn using the platform control,I sure need some help/advise. You out there VOODOOMOJO
