Tim McArdle
Looking for advise on a 34/19 lift we just bought that the boom controls will only function in the "down only" mode. Machine is flashing code 10 which has something to do with the circuit boards which are blue by the way, and also when we try to lift we get code 3 which has something to do with the level sensor. I've checked the level sensor and it's seeing movement however from what I've read in the manual I should have only between 0-5 volts as a signal on I believe the blue and yellow wire on the sensor (X and Y axis) but its showing close to 22-24 volts and changes when tilting the sensor. Outriggers are working fine and the machine is seeing that they are down as per the indicator lights. Machine was bought with leaking cylinders and we've repaired those since purchase. seen talk of software that might be able to communicate via laptop to maybe see what the machine is seeing but not having any luck finding it. Don't mind buying parts it needs but just don't want to throw stuff at it that is not needed. Also read about a whole different operating system to get rid of the electronics??
