I am working on a TMZ-34/19 towable lift. It has a "no power at controls" issue. I have a copy of the electrical schematic as well as the troubleshooting chart. I've made my way through the steps to the point that no voltage is going to the keyswitch (no voltage leaving the board from keyswitch pin 2). I removed the connection board and noticed a resistor is burned up. It is # R1 locate in the lower corner. see picture attached. It no longer has legible information on it for me to find a replacement resistor. Does anyone know what resistor should be used here?
I've seen many posts about blue board vs green boards and making an upgrade to the blue. On the GCiron page it appears that the upgrade kit is no longer available. I'm hoping to get the resistor replaced but if that's not the only item damaged then I'll have to continue trying to figure this out.
This is a T3499-695 machine
