genie s-60
Discussion in 'Forklifts/Telehandlers' started by SHELBY BRYANT, Oct 6, 2018.
i have a 2005 genie s-60 it starts for 5 seconds then shuts off anyone have an idea.
  1. anyone
    1 vote(s)
    100.0%
  2. help
    1 vote(s)
    100.0%
Multiple votes are allowed.
  1. SHELBY BRYANT
    SHELBY BRYANT Member
    Oct 6, 2018
    8
    clewiston
    i have a genie 2005 s-60 it starts up for 5 seconds then shuts back off cannot figure it out. anyone have this problem before.
  2. willie59
    willie59 Super Moderator
    Dec 21, 2008
    12,486
    Service Manager
    Knoxville TN
    Engine? Gas, diesel, propane?
    Machine s/n?
  3. SHELBY BRYANT
    Oct 6, 2018
    8
    clewiston
  4. willie59
    Dec 21, 2008
    12,486
    Service Manager
    Knoxville TN
    Still gotta know the machine s/n, Genie has been making the S-60 for a whole bunch of years and they've changed considerably over those years
  5. Knepptune
    Knepptune Senior Member
    Nov 22, 2012
    691
    Indiana
    Check your alternator, coolant level and engine oil. If the machine senses any engine fault it won't run for more then a couple seconds. Alternator and low coolant are most common. Low engine oil will do it as well.
  6. SHELBY BRYANT
    Oct 6, 2018
    8
    clewiston
    it looks like an air cooled duetz engine. i will check that tomorrow and let you know
  7. Johndoe
    Johndoe Active Member
    Sep 20, 2016
    28
    USA
    You have an Ignition start Module (ISM) inside the ground control Box that is responsible for keeping the engine running
    You can bypass the ISM's control by jumping power to terminal 21 on the main terminal strip.
    If the engine stays running:
    -1-Oil pressure or oil temp switch is grounding ISM terminal 10
    -2-Alternator is not producing a tach signal (if you have a deutz, remove the access panel on the right side of the engine to gain access to back of the alternator,
    ------when looking at the back of the alternator:
    ---------- (1 o'clock) Tach Signal (with engine running 7.1vdc and 313Hz)
    ---------- (4 o'clock) Power input to field coil (gets power from terminal 21 inside the ground control box)
    ---------- (8 o'clock) Battery Positive (constant 12v)
    -3-Power ISM terminal 4
    But, If the engine still dies:
    -make sure you are getting Good power and Ground to the Fuel shut off solenoid (located on the front of the engine above the idler pulley)
    --is you remove the fuel shutoff the engine should run indefinitely
    Useful info on the ISM
    Ignition start module terminals 1-10
    1= Output to starter relay enable (CR1 terminal 86)
    2= Input, Tach signal input (this is read in Hertz, signal is produced by the alternator)
    3= Input, Start Toggle switch
    4= Input, Aux pump toggle switch (power on this terminal will cut power to terminal 9)
    5= Ground (should have less than 1Ω to battery negative)
    6= Input, Battery voltage (from CB1)
    7= Input, Battery voltage (key switch power, TB23)
    8= blank
    9= Output to Ignition relay (CR2 terminal 86)
    10= Input, Fault detection (will receive a ground from oil pressure and/or coolant temp sensor. circuit is ignored for 5 seconds after starting engine)
    *Note: Power inputs must remain above 10.5vdc while cranking engine
    HERE IS A LINK TO GENIE TECH TIP FOR ISM issues:
    https://www.genielift.com/docs/defa...oms/no-start-ism-models.pdf?sfvrsn=a40a768a_2
  8. Geoff Lott
    Geoff Lott Member
    Oct 20, 2018
    23
    Mississippi
  9. Paul Council
    Paul Council Senior Member
    Oct 12, 2018
    377
    Somewhere
    Air cooled deutz also have a shutdown switch on or near the belt tensioner. So if your fan belt brakes your engine shuts down.
  10. SHELBY BRYANT
    Oct 6, 2018
    8
    clewiston
    sorry so long to reply , it was the alternator. thank you
    Geoff Lott likes this.
  11. Geoff Lott
    Geoff Lott Member
    Oct 20, 2018
    23
    Mississippi
    Yea first thing always to check on 2011 Deutz with your symptoms are the belt as the machine gets its tachometer signal from the alternator so if belt breaks machine cranks but no RPM signal is fed to ISM so engine shuts down...then move onto measuring HZT output of alternator
  12. Geoff Lott
    Geoff Lott Member
    Oct 20, 2018
    23
    Mississippi
    I’ve never seen these on the 2011...not saying they don’t exist...the tensioner is just that 17mm bolt and the 8mm Allen bolt with one pulley and brackets is all I’ve seen..I’ll keep my eyes open though..must be old machine...you got a picture??...everything I’ve seen is the orange tach wire sending signal VIA the alternator to the ISM
