metalman
I have a 1998 S-60 dual fuel with an LRG 423engine, serial #2784. The problem that I'm having is the machine will run fine on turtle mode, but when I switch to rabbit mode or depress the pedal in the basket, the engine will spit and sputter and stall. It always starts right back up again. I have ran a bottle of sea foam through the gas tank, thinking that it may be an ethanol issue. I have also changed the coolant temp sensor. Any ideas or suggestions would be greatly appreciated. Thanks
