Genie s-125
BILLYMORGAN
MIDLAND, TEXAS
I have a genie s-125 , we have replaced the turntable tilt sensor and re-calibrated as per genie, we now have the same issue again, any suggestions ?
VoodooMojo
Baltimore, East Coast USA
Sr Technical Service Representative
It is usually the Green/White wire at pin 20 of J3 that pulls back in the connector and does not make contact that causes the issue you are having. Backprobe the connection at p20 of J3 when the machine is level and there should be a voltage of approximately 2.5 volts. Use p14 as the minus voltmeter lead point.
Also be sure the machine is perfectly level when attempting to calibrate the sensor and the Green/White wire must have between 2.2 and 2.69 volts present or the sensor will not calibrate.
