arcarocket
So here's what happened. We used the machine inside our warehouse and has worked fine, we were building another building next to our existing and needed the lift so we moved it outside to the new building for them to use during construction and moved it outside with the Forklift (picked up from side, tilted at about 20 degree angle, and drive it out onto the concrete pad. It hasn't worked since.
The machine powers on but when you try to raise it or steer it, the machine just beeps. The platform controls and ground controls provide the same result. I had batteries inspected and Interstate Batteries guy said they were good and not the problem.
Serial Number: GS3203-51235
We did go through service manual and tested the control box and it seems to be putting out correct volts. We were able to jump across 2 poles at control box to get lift to raise/lower, so we know hydraulics are good.
I assumed it was some "Tilt Sensor" or something dumb that got triggered during the move of the lift between buildings. But Genie said there's no "reset" or anything like that.
Any leads/help guys?
Thanks!
Thanks!
