FrozenR190
The Genie GS1930 scissor lift will work with one person seeming just fine but will not go up with two people in it. Did find older thread on this too which was very helpful. Tested pressure at test port at about 2400lb. On the valve block turned system relief valve and lift relief valve all the way in (about 3 turns) and pressure only increased to about 2600lb-2700lb. Still will not lift two people. Book said to set at 1800 to 3700. Took apart the adjustable relief valves and found no noticeable problems. Put gauge on line out of pump and only get 2500lb. Didn't know if air in line at that test could skew pressure reading. Should the pump higher? Removed return line and when raising for the first moment no oil comes out but then flows starts (when lift goes up). Any suggestions or input would be great. I see in the manual some models could have a overload relief on the lift cylinder but I don't think this one does. It's GS1930 GS3008B-96718 serial#
