Genie electrical ?
bdmb
manitoba
Hi everyone. I joined here cause I bought a genie Z45/22. What is the proper way to remove and install wires on the terminal block in the ground control panel? Thank you.
tool_king
new jersey
road mechanic owner
You can stick a pick in the hole next to wire to unlock the wire from the terminal block.
bdmb
manitoba
Thanks, I was using a heavy paper clip and it was bending. Was scared to break something. I used a small screwdriver and pushed hard till the wire came out.
Rentalmechanic
Memphis,tn
Yea pushing it in you see the mouth open to take the wire try a empty hole and you can see how it works ..... no dirty jokes intended lol
boomtech
Quakertown,PA.
Owner:AERIAL EQUIPMENT SERVICES LLC
Z45/22
A WAGO tool....basicly a small flat head screwdiver works just push straight in and the wire releases. If your a tool nut like myself call GENIE SERVICE they will send you a few for free,they used to come with all new genie products but now its all ALC controlled so no need for it any more...peace Bob
