H.M. Marion
Hello ,new member posting here, I recently purchased a Genie 2032 scissor lift serial 20281.I installed new batteries and a new ECM. Everything works great except the brakes will not release once the platform is raised or the platform drive switch is switched to low speed. When the platform is in the stowed position and the speed select switch is in high range the brakes release as they should. I teed into the pressure brake line at the manual release valve and I get 450 psi when the drive switch is in high and 200 psi when the switch is in low. should these pressures be the same? any help? Thanks in advance
