Warnec
I have a Gehl 7810 at work that won’t start. A coworker was using it, shut it off to talk to someone and it wouldn’t start again. Things I’ve tested; oil pressure switch seems ok, crankshaft sensor reads 130 ohms, replaced lift pump, old one wasn’t pumping at all. Cracked open all the injector lines and have fuel to each one. I noticed the glow plugs don’t have power to them but it’s in a heated shop so I’m not worried about that right now. I can get it to pop off on either (don’t worry I’m barely spraying any in there). There is a solenoid of some sort on the bottom of the injection pump (Perkins # 2644N204 12v) when I hold my hand to it and someone turns the key on, I cannot feel it actuating. The only other thing I can think of is possibly the ecm, it had an issue when it was running that if you brought it down to an idle it was stuck on idle until you shut it down and let it sit for a while. If anyone has any ideas I’m open to suggestions. Thank you.
