Terryz
I have a Gehl 6635 that won't hold neutral; the hole in the flat steel arm and the pin it pivots on in the controller assembly is worn, allowing right side wheels to creep in neutral if the operator doesn't keep holding it neutral. This is an early series 1 machine; dealer wants $840.00 dollars for a new controller. Is there a fix for this? Maybe having a larger pin and holes machined or is there an alternate supplier that sells these for less? Thanks, Terry
