Yeah, it's never easy to follow another wrench and pick up where they left off, pretty much have to check everything. Getting engine on TDC mark doesn't insure your on firing TDC, it could be 180 deg off on exhaust TDC, you have to make certain you're on ignition TDC. And if I remember correctly, you're scribe marks inside pump should line up when you're on proper BTDC as required by engine maker. On most diesels, that would range from 5 to 12 degrees BTDC. Again, memory a little vague on that, can't be for certain. Also, that CAV pump has to be purged of air before it will deliver fuel, I'm thinking they had a bleeded screw on top of the governor housing to purge air from the innards of the pump. Hope this helps a little.
