damon1
I have a 1947? Caterpillar road grader that I just recently purchased. If anybody could give me some advice on diagnosing the problems it would be greatly appreciated. It's a 3U serial number. My back ground on heavy equipment and working on diesel motors are none. I bought this grader for farm use only. The pony motor runs great, the diesel motor runs great. The diesel motor starts right up with no problems. The grader has been sitting up for several years with an occasional start up every three or four months per previous owner. Here is the first problem. We noticed the oil was watered down with diesel. You could smell the diesel and by the velocity of the oil really watery it looks like an almost 50-50 mix of diesel and oil. We drained the oil fuel mixture and filled it back up with oil. We started it back up and within 20 minutes in was full of fuel again, the oil ran like the consistency of water almost. There must have been 10 gallons of diesel fuel mixed in with the oil. What can cause such a large amount of fuel to enter the oil pan so quickly and at the same time the diesel motor run like new at the same time? No black smoke out the top or nothing? The second problem I'm having is there is a large amount of hydraulic oil leaking from the vent on the steering box. Thanks in advance.
