You asked me earlier: “I am wondering if you have something transmission/driveline related that is loading it up. Do you think that could be a cause?”
In reverse it does seem like the brakes are on. Just moving backwards with the blade up, it will stall if I don’t clutch it.
Another question you asked:
“Does using the hydraulics while sitting still cause enough load to see symptoms?”
Just what am I looking for here?
Hi sorry I have been at a job where we have no connectivity to anything. Home having a restock and resupply.
So what I was getting at was seeing if you have a problem somewhere other than the engine causing your issue. So something causing the engine to work really hard when it shouldn’t have to, causing black smoke and bogging down.
The hydraulic loading idea was if your Hyd pump might be able to give the engine a bit of a load not related to the driveline. It probably wouldn’t give much if it is a gear pump, but if you pull a couple Hyd levers sitting still and it bogged down and blew smoke I would think it would most likely be an engine lacking power problem. If the engine didnt change note I would think less chance of engine as cause. But this isn’t a perfect test idea and may not give good results anyway.
It sounds like it might be more driveline related if it is only doing it in reverse
now?
The steering issue could be getting you honed in on a possible cause.
So your dozer has a manual gear box and clutch?
What do you mean by steering too easy?
Is your steering system seperate leavers and brake pedals?
I have an old fiat bulldozer that once got a stick wedged up where the brake pedal shaft went in the case causing it to stay locked on, have you checked the brake pedals are returning freely if you have them?
