Black smoke and lacking power sounds like too much fuel (or fuel at the wrong time) and not enough air to burn it! Did this start suddenly or has it been a problem since you got the dozer?
How long have you had the dozer?
Have you checked for a blocked air intake or air filter?
I’ve had the dozer for a few years. It was such a honey of an operations dozer. Initially a friend dropped it off at the church camp I was building out of a hay meadow. After awhile he offered me a deal I couldn’t refuse and I bought it. At that time, wrong decision, about all I knew was how to drive it. I knew to check all fluids before I got in the seat, but that’s about it.
Then I got a crash course in blown hydraulic lines and leaking cylinders. Little by little I began to grasp the importance of clean fuel and air filters. When I retired in 2019, because of failing health the dozer sat idle for probably a year, maybe longer.
When I started using it again, it just didn’t seem like its efficiency was as good as it should be. The black smoke loss of power began to show up and my son, who was an OTR truck driver (he owned his own truck) told me to pay closer attention to air filters, fuel filters and quality fuels. A little while back (I’m not using it everyday) I began to notice this fuel in oil. However, it wasn’t very much. At first it was puzzling to me, instead of having to add oil it would sometimes read just a little over full.
However, best I can remember, that’s when loss of power began to be recognizable to me.
I pulled the injectors, had them tested (all good).
I just knew getting this sp working properly, changing fuel and air filters, would solve the problem and it may be when I get this sp overhauled properly every thing will settle in. Gasket kit is supposed to be here tomorrow and pump guy is getting me the number for the seal. Hopefully my cobbling will hold up until I get the new seal. I’ll double check the fuel suction side, the air flow, etc.
Is there an adjustment device on the fuel side that will allow me to tweak till I get it fine tuned?
I’ve already removed the fuel shut off valve that had the 1/8 inch ID thinking maybe it was too small. Tomorrow i’m planning on replacing rubber fuel supply line and installing the proper shut off valve.
