Engine swap for A66 - need some flywheel help
Like I posted earlier my A66 has issues and after pulling the head I can see that the #4 cylinder has a pretty long vertical crack, a broken rod and piston. I don't know if there is any crank damage also. All the cylinders have a pretty good lip so it's time for a rebuild of some sort, so it's going to be more than a few bucks for a sleeve, piston and rod - at least $800 for a kit.
So... it gets close to another option which is to put an IH DT360 engine in it ($1000 with radiator, starter, alternator). It's coming from a truck so the fuel pump won't quite be right, but probably good enough for farm work. The biggest issue is mating the allison torque converter to the flywheel on the dt360. The ford engine appears to have a flywheel instead of a flexplate - is this normal on loaders? Any experience would be appreciated.
Thanks,
Pat
