tnc110
Get on an old john deere diesel farm tractor(any of the old 2 cylinder)....go down a grade....pull the compression release. ...JAKE BRAKE....same principle....
I'm not fighting, I'm attempting to explain how they work but apparently I'm failing. Information directly from jacobs:Principle defined as: a general scientific theorem or law that has numerous special applications across a wide field.
Same principle.
Jake brakes do not open just at tdc...or atleast not any that I have. The isx has a special cam to help jake braking...but that's a whole nother can if worms.
Fight it all you want, but the load leash is the same principle as a jake on a 3406 etc. They both release compression by opening the exhaust valve. ...same principle....
Not really but you do get to take advantage of some added friction yes.
A jake bleeds off compression at the top of the compression stroke to steal the return energy out of the cylinder.
The load leash description is much longer but it holds the exhaust valves slightly open during the entire compression stroke to force more air against the closed vgt and create more back pressure.
A jake makes the engine do the braking and a load leash assists the vgt in braking, so definitely not the same principle. Just because they both hold the exhaust valves open at some point in the engine cycle doesn't mean they work on the same principle, the cam also holds the exhaust valves open and it's also not an engine brake.
No, it wont. It's holding the exhaust valves open for the entire compression stroke so no energy is wasted compressing, it's basically like opening the unloader valve on an air compressor. You don't get any gain from the return energy but you don't lose any energy on the compression stroke. There might be some net energy loss over just coasting but it won't be much.
If a truck were to be equipped with a load leash only, no vgt, it would still provide engine braking, in the same way that a jake brake does. It does not need the VGT to work. See my example above with the old John Deere....there is no VGT on a 2 cylider deere, I promise you! Yet engine breaking is still achieved, VERY much like a jake brake, might we call it the same principle???
chevota, I'm am sure you know far more about diesels than I do, but you are missing the boat on compression braking.
Yair . . .
Fellers I know nothing of Jakes but I straight up don't understand the following statement . . . .
Any compression release I have used is for the purpose of releasing the compression to make the engine easier to crank.
To take that theory a step further . . . .
We get our Johnny Popper and pull up on a slope where the compression in the cylinders will just hold the tractor on grade . . . we then release the compression and the tractor runs away.
How is that in any way an analogy to an engine brake?
I always thought the most braking you could get out of an engine would be for the drive train to turn the engine against compression with no fuel but apparently the Jakes do much better than that.
Cheers.
