Ray450
- Joined
- Jan 15, 2015
- Messages
- 39
- Location
- GreenvilleTexas
- Occupation
- Police Officer and offroad race promoter
Just bought a 555E backhoe with 4n1, 3300 hours 4wd, and quick connect WB rear bucket at auction. It's my first piece of heavy equipment other than farm tractors. I have 144 acres of mixed hay fields/woods and usually run a offroad M/C race a year on it, with a small M/X track. Have rented a dozer (JD 450) a couple times and had a buddies skid steer out once. I've only had about an hour on the backhoe so far, still trying to get a feel for the controls. A couple of issues, that may not be issues. 1) Once revved, there seems to be a lot more pump noise/rattling from under the seat/under the B/H controls. Normal? 2) I was also a little surprised that if in 4th, and revved in gear to try to go, it basically won't move but makes a lot of that same noise. At 16,000 pounds though, I'm guessing that's normal, my tractor would probably have a hard time moving in 4th/high and it's 1/3 the weight and only 20 H/P less. Before spending much time on it or getting it anywhere near my inclines, gullies and creeks, I want to fix the E-brake which doesn't work, and the accelerator pedal that doesn't return. I had assumed it was just packed with crud and not returning to idle, but after messing with it, it's broke and in pieces. So, once I fix those issues, I also want to do a lot of regular maintenance (I have a book), fluids, filters, a million grease fittings ect ect. Where's a good online source for these type of parts? Anything I should focus on at these hours, or not worry about? Any advice or help would be greatly appreciated.
