I am trying to replace the rubber boot on the gear shifter but wondered if I should pull the gear shift lever and spacer off the transmission or somehow wrestle the boot on with the shift lever and spacer in place. If I pull the shift lever and spacer off, which may make it easier to get the boot on...does the shift lever just drop in place then bolt on when reassembling? I fear pulling it off then there being some unexpected issue (alignment etc) putting it back together. I looked at the repair manual and it looks like to boot is on the gear shift when it is inserted thus it may be easier to pull the shifter off then reinsert. I want to avoid creating a bigger repair problem than just a boot if I pull the shifter out so a bit hesitant to blindly pull it out without asking those with experience. Thanks.
