EthanJTWade
Hopefully someone may be a little smarter than me,. I have a 1970 ford 4500 bought 6 years ago and have been fixing it up as it breaks down on me. ( I did search the forums and Google a ton in hopes of finding info with no luck of finding what I need)
The extend a hoe cylinder is leaking and I'm trying to find out what seals I need for it before I tear it apart ( it currently still works and dont want to loose the use of the backhoe atm) as well Im trying to find out what sort of Wear guides I need to tighten things up as well as bushings and anything else I can fix up on it.
The backhoe name plate says it's a 19-561, but I can't seem to see any parts break downs showing the extend a hoe section.
I also have a rotary swing cylinder on this ( from my understanding it wasn't common in Canada)
I found a seal kit for it does anyone have experience with re sealing them? Pictures or guides? So far I've been able to just figures things out and torch/ reweld things that have broken but I'm now in need of some help/guidance.
