I'm more amazed you're doing dirt work in the middle of winter.
Pretty much everything happens June-October here.
We had zero frost in the ground until 10 days ago as well. Usually earth works die off in November/December, but projects just kept plugging forward this year. The worse part for me has been the endless mud since October.Its unusual. If we hadn't gone below zero for a week about 10 days ago, there wasn't even any real frost.
It does all of that. I can separate the forward drive speed from the reverse drive speed. It also has a decel pedal that slows the engine RPM or slows the drive speed and keeps the rpms at a set level or it is a typical accel pedal. I have not run this machine with a mulcher yet, but I don't have any destroke issues with a 450B that I currently use to mulch with.I will never understand hydro dozer controls having gears. Let me set forward and reverse speed separately and give me a decel pedal for track speed.
Has Case fixed the issue with the pump destroking with mulchers?
I stopped by border equipment here in Atlanta they have 2 in stock. I believe the going price is 150k.
Seems like a very neat machine. To me I would think it needs more HP but I have not got to use it. How does it do under heavy load turning in mud will it kill the motor?
