My obviouse answer to your question is never, as I need the coins for rebuilding these items, but the true answer is in your hands to firstly check the levels min weekly and secondly change the oil-s when you think its due for this task, oil is a small cost due to the low oil quantity usualy found within these areas, 2'000 hours is a fair amount of hours to stuff a load of BHP through a small amount of oil, take Excavators as an example, the F/Drives go through Hell of a time usualy in high speed track mode driving about for often little need with little to no oil service work done, when the oil drain-fill plugs get pulled the oil is usualy black ,smelly and possibly with sparkles, there might be a need to improve your service outlook if you are the owner, sadly J Deere equipment is not represented in the U.K. so I honestly have no idea about what happens within them, but the case with the small quantity of oil in I would refresh on a regular point posibly every other Engine oil change.
just my thoughts with no knowledge of JD iron tctractors
