Dmax, the blade only gets in the way if you drop it off and reverse out of it a few feet, you dont need it near you so dont have it causing trouble for you, the rams that you just left dangling again is doing you no favours, firstly it make the customer think that you are lazy or clueless, well it does in the U.K. I can tell you that the owners would soon bark up a few verbs on this point, so suck the rods fully into the cylinders so they ballance, then hang them up on the pins and tie the rods to the cylinders with cord as they will drift out over a few hours, this also stops you banging your head on them or any damage to them, your cribbing up is also a bit small time and at best a bit unsafe, you need to poke a block under the F/D case and get a few baulks under the beam,those few sticks you poked under the hitch again look like a lack of experience at this sort of work, I would not be happy to start up the engine and power off the hub nut with your cribbing effort, so think about this point and work out what you might do better next time, as for stuffing things back together lets see the cogs first, just as a point what is going on in the opposite drive case, as it usualy works out best to pop both sides down, I can strip both sides on a good day on a D6/7 that is tracks off, frames out, rims blown and cases off with the gears stacked on a pallet by myself, the owners usualy have the blade removed for me awaiting my efforts, I also tell the owners to have a pallet of timber baulks or rail timber in around 3 feet lenghts ready for me.
tctractors
p.s. the hub bearing I remove in about 5 min's by myself or about 4 mins with the owner sat in the pilot seat, you must have sweated some on this task and wasted about an hour?
