MCFooter
Fiat Allis 7G-B Bucket lift cylinder - Rear pin Removal
Just reaching out to see if anyone has any suggestions on removing the REAR Pin of the Bucket lift Cylinder on a Fiat Allis 7G-B Loader. (Item 2) Part # 70625755 PIN, rear pivot, cylinder. (Hex Shaped Pin)
I was able to get the threads inside the Pin Cleaned up and a 3/4-10 bolt installed almost 1.5".
I first tried a decent size slide hammer on the Bolt which did not phase it.
I then made up a puller piece similar to a Huge socket (~4" Pipe coupling and 1/2" Plate w/ .75" hole)
Tried some light heat and 1/2" Impact with no luck.
Stepped it up to some Serious Heat and a 1" impact and still no movement at all. Granted I could have used a little more volume of air on the impact but was able to bend the 1/2 Plate with still no movement of the Pin.
Am I missing something?.. I have not removed the Skid plate to look at the inside of the pin.
Any next step suggestions would be appreciated... Removing the Cylinder because 2 of the bolts (item 17 at rear) broke and need to be removed.
Thanks,
Mike
https://drive.google.com/file/d/1i47WPJ8mXR_gxBuuZdwaQVvHJcOVaYZG/view?usp=sharing
https://drive.google.com/file/d/1DJelM_3oaHfJ53SmIUgyz4lAew-pSKAy/view?usp=sharing
Thanks,
Mike
