Tell us about your tractor Rusty.
I replied to your question in the loader section, but if it's a dozer it will be a slightly different linkage arrangement.
Thank you so much for replying.
It is a Fiat Allis 14C and the serial number is 051184. I sent away for a manual twice for serial number 050101 and up and they ended up being the same book and not having anything to do with my machine.
When I apply either brake both tracks stop.
The following list are the things I have already done.
Replaced both brake bands.
Cleaned entire brake system.
Rebuilt power cylinders that operate brakes
My machine has valves up front by the steering clutch handles which operate two small cylinders that apply the brakes and I cleaned and replaced all o-rings.
Installed new brake hydraulic pump which is the type that is the transmission pump and brake pump together.
I have bled the machine several times with no result.
I installed 2 new filters.
I know that I have no lines crossed because I took photographs before I disassembled it and double checked the photos and all lines are where they originally were.
Before I worked on brakes, I had only a right brake and right steering clutch that worked correctly. Left steering clutch worked only sporadically after the machine warmed up.
I took brake distribution valve to a hydraulic shop and had them tear it down and clean it and replace o rings.
After the brakes were completely done, I have left and right brakes and if you step on either brake it stops both tracks. And neither steering clutch works.
What insight can you give me. I would appreciate any input you can give me.
Respectfully,
Rusty Rogers
