Had another little problem with this lift which was minor but annoying. It being only 2wd and very heavy, it was having a difficult time climbing the slightest of incline. One drive wheel would stall out consistently and the other occasionally. Got tired real quick of winching this big ole sumbitch around too.
Yapping with a buddy whom formerly worked at a JLG dealer in the Chicago area, he sent me service/training manuals on the "F" series hydraulics in both Racine, and Eaton. With this information, I was able to accurately set system pressures which were all over the board, locate a defective check valve in the main pump discharge line, balance the drive wheels counterbalance valves correctly, and generally get the machine to perform as designed. It worked very well on flat terrain but again, wouldn't climb the slightest of inclines easily.
Armed with this information pertinent to the machine and having the testing equipment to isolate and troubleshoot I took after it. I plumbed in two flow meters, restriction valves, and gauges to measure things. Ultimately I discovered with both wheels locked via ratchet straps to timbers the tires were resting upon precluding rotation, the left rear, (looking from the rear) was stalling easily. Both drive wheels were equal in pull till the hydraulic drive pressure was increased to 1250psi indicated at which the left rear tire would cease pulling. Obviously this wheel motor was slipping or bypassing fluid internally as the flow was still there. Removing this drive wheel from the system through isolation, I was able to apply 2000 psi to the other wheel easily with minimal internal leakage. Isolating the right drive wheel the system again would only achieve 1250 psi again. Looking at the flow meters, I was running about 6gpm through the system and this left rear drive motor was bypassing almost four gpm internally while the motor was stalled.
Rebuild kits, or replacement motors are NLA so I go online and found a pair of drive motors .1ci larger in size and ordered them. With the replacement motors installed, actions and reactions are smooth and predictable and the wheel slip is gone. While the machine is still very heavy, the very same inclines it would not climb are easily surmounted. All good I suppose. I've not converted to diesel as of yet but that is in the future as this gasoline engine is tired and very underpowered for the unit.
Manual sent me:
Motors out. Yellow one is bad. Apparently black one has been rebuilt, or replaced at some point:
Defective motor replaced:
Counterbalance valve(s) to adjust drive wheel actions. Yellow circle are hydraulic lines directly from the spool valve section driving the machine:
Looks a bit better after everything was pressure washed clean. Lot of dirt and oil of course was removed.
