buddie
I have a 1987 Ford F800 dump truck, 5 speed. Just had engine rebuilt. My problem is with the transmission. I only use the truck onsite work. The transmission will continuously lock up and I have to remove the gear shift in the floor and line up the gears again in order to get the gear shift back in place. Works ok for a few minutes and does same thing again. Truck will not move in either direction. Clutch is very hard to push. Is this problem in the gear shift?
Would appreciate any help with this problem
Warm regards,
Ron
Warm regards,
Ron
