Graham1
Instead of sticking extra weight out the back, had you considered buying a bit of thick plate and bolting it underneath the back. Most machines have bolts underneath that could be extended. You then wouldn't destroy your zero tail swing or have to get it specially fabbed up to fit the shape of the existing counterweight.
Also I've heard the jumpiness is often down to poorly set up check valves. Does your machine have them fitted? If so you may be able to bypass them to check if that is the problem.
Graham
Graham
