This voltage claim cannot be correct as the C12 is fitted with the D 1015 engine (V6 water cooled) fitted with a 24 volt system, so a charge rate of 27.5 would be a good area, anyhow if you look at the display panel constantly as the engine is running, just before it calves down spot the first light to flash as this is your fault, a common 1 is low coolant level that is often fixed by removing the sensor and cleaning it and re-fit also top up water level, the charge light is often just the light that comes on first at shut down that you notice, its also the common thing to have fuel dramas with these crushers.
tctractors
