Welding across the stick could potentially cause a stress point that leads to a crack. If you did a kind of half circle weld across the stick would be a much better alternative. Some people have used silicon caulk to keep water out but unless the stick is going to be digging under water all the time I can't see the stick just rusting away. A weldable primer before welding the thumb mount on could be a good option.Why ought it not be welded across the stick?
