jadcalmech
Hey guys it could be a couple of things there is screens in the banjo fittings and they are a little white colored screen they are very fine and plug easy. Komatsu uses three control valves they are NC/CO valve which is neutral control/cut out control on each pump and they both share a TVC valve torque variablr control these valves all have to be set with gages on unit and is quite the project. there should be a computer bypass switch on these hoes and that throws it into a mid mode and you can see what you have after you try that. Good luck
