No problem im trying to pull these panels off at the moment. I should have it off soonThanks for the pump pic.
See if you can pull out any service codes.
Ok its operating normally right now. Let me see if I can make it go back to slowThanks for the pump pic.
Where is there supposed to be a blinking light?Thanks for the pump pic.
I believe there are both power and grounds in each end of the PVC /connector.Something is going on with either the connector or the PCV because I tightened it down and it went to being slow again. Loosened it and push it on the right side of the connector and its fast
Thank you daveSee screenshot below,
I need to unscrew the EC to see the light. I might have to do that tomorrow. Its not just one side of the connector as I thought its both sides as you mentioned about the power and grounds. I have it positioned perfectly to where to problem is gone but the wiring harness connector is definitely not going to sit right while its moving and digging.I believe there are both power and grounds in each end of the PVC /connector.
Makes sense that the performance would be wonky with a loose connection.
With key on , the light on the PVC and the EC should be flashing approximately once per second indicating that they are powered “on” .
Yea I think theyre locked in positionThe pins you have circled , are they locked in that position or can they move in and out ?
When i was looking at the PVC all the pins looked great but those ones that you circled I saw they looked broken on the end. Ill go out and take a pic of the PVCWhat condition are all the pvc controller pins in ? Are all the pins aligned ?
What condition are the terminals in on the highlighted connector terminals in pic below ?
What condition are the terminals in on the highlighted connector terminals in pic below ? They look a bit sketchy from here .
