Georgia Iron
- Joined
- May 6, 2012
- Messages
- 886
- Location
- USA - Georgia
- Occupation
- Concrete building slab and grading contractor
I was unfamiliar with what it can do.Too big, to long, it would be awkward as a cub bear for most telehandler work. Very few jobsites I've been on, have room for something like that to get around on.
I've also set up too many dumped over telehandlers, to trust the average telehandler operator with something this size.
The video is a hilarious promo piece " we don't even need cranes" and "nothing else is like this" . Well, its basically a crawler crane that can't swing.
The real push behind bigger telehandlers is simply to get away from the certification requirements of crane operators. Typically anyone and their dog is allowed on the jobsite telehandler. Making ever bigger telehandlers isn't the answer.
DESCRIPTION
In a category all its own and affectionately nicknamed Trackzilla, the XR50100-G smashes the limits of material handling capabilities. With a record-breaking 100-ft maximum lift height and forward reach of 75 ft, this telehandler is a game-changer in the world of heavy lifting. Xtreme’s first tracked machine tackles rough terrain with ease and can lift up to 50,000 lbs. Engineered for operator safety and comfort, the XR50100-G, is built with all the features that make our machines so popular with users.- 360° operator visibility
- Suspension seat
- Easy service access
- Protected tilt & extend cylinders
- Steel hydraulic & fuel tanks
- Long-life Lexan labels
- Large-capacity fuel tank
- Trunnion-mounted sway cylinders
- Melonite pins
- Dual auxiliary hydraulic circuits
- Steel dash
- Triple batteries
- Hydraulic cab lift/lower & rotate
- Rear back-up camera
- Ductile steel manifold
- Easy cab-mounted grab handles
- Master disconnect switch
- Boom lift point
- Manual lowering valve (cylinders)
- Large cross-section boom
- Easy tiedowns
- Heavy-duty pre-cleaner
- Additional high-pressure hydraulic filter
- Multi-function display screen
- Long-life boom rollers
- Solid steel plate chassis
- Rear axle stabilization (RAS)
- Back-up alarm with light
I have had to clip a grade closer to level with my motor grader for the big 300s on a few jobs. Watching them try to track around unlevel areas and seeing the jib move about is a little unnerving.
Definitely needs some space to move it around.
