Epic 17A dead shaft fail
epirbalex
Akitio
peasant
Not sure what is on the opposite side in that picture of the assembly.
Looks like it could be pushed with a small porta power jack from the inside?
Isn't that a nut towards the center of the frame between numbers 13 and 14?
Nah , the end of the shaft sits in the housing , that is the nut between 13 and 14 though
chidog
wa
And since its junk and broke cut the end off after the nut, and jack it. As it looks like the end after the nut extends into some housing? Don't know never saw one.
LG 78
King Country NZ
Cheers for that OM will look very closely into it
Mean while I have managed to get it to move wit the grease gun method
I have to buy a new gun to complete the task as it took every ounce of strength and an extension on the grease gun but it moved half an inch with a great sounding bang
interv8
New Zealand
Grower
Hi LG, I,m up in Pukekohe NZ, I've got a couple of D717a,s so am interested in how you got on with yours, and whether you have a parts donor machine?
LG 78
King Country NZ
Bit time poor at the moment I shifted the shaft about 40mm with the grease gun before the grease started to escape around the edge of the cup but it did the job
It has moved the shaft out enough to now weld threaded bar onto the end and pull it out
I do have a few parts here from a donor machine that I wrecked (a good dead shaft for one thankfully)
I sold a CCU up your way a couple of months ago Was that to you?
Im in Te Awamutu 021445853 if interested
interv8
New Zealand
Grower
LG good to hear your still having a go, the grease idea sounds pretty good, i dont know about the ccu, not me, i will give you a bell. Murray Wymer 0274380269 i posted a bit on youtube under wymerfarms, cheers
AU.CASE
NSW Australia
Grazier // Rancher remote NSW
Interesting thread, decades ago a contractor with a fully rebuilt D7 17A lost a "X shaft" building roads in a remote neighbouring property.
To recover it, a 4wd truck was brought in to pull the broken side [whilst the other track drove] to try and keep it vaguely 'on track' which was the problem.
Eventually it was at the public road and low loader to haul it away for repair, when I would post some images but being 'younger' I didn't have a camera in 'those days'.
D6 Merv
Coromandel Peninsula. New Zealand
Self employed bulldozing contractor with a D6D D4E
Hi LG78 assume you got terrible cat out to pull sprocket; and later on push it back on ?
Or did you know someone else in waikato with the puller gear ?
Cheers Merv
LG 78
King Country NZ
Hi Merv yes had to get them out to split track and pull sproket much easier with the correct tooling
Have to pay up front these days for one off jobs he was a good bloke but turned up with out a functional gas axe which pissed me off for the price I had to pay
bobsyruncle
canada
Heavy-duty Mechanic Retired
thought I'd check on how you made out with the axle.Glad it worked out. We used to do this in the field in Alberta.. Cheers from Canada
LG 78
King Country NZ
Well sadly this shaft is fighting me for every mm of movement
I have been extremely time poor running the farm etc but long story short, I moved it about 45mm with the grease gun then welded a nut onto the end of the shaft and made up a puller
So far I have put 86kg bouncing on a 6ft bar and cant get it to budge any further
Not completely out of ideas yet but im unsure as to why it wont just pull out
Cheers for checking in
LG 78
King Country NZ
Good to see it out LG
So basically that thermal lance bored a hole about 3" deep into it ? and U then welded that threaded bar into it and pulled it out with the nut and a spacer
Hey Merv
We went through to about an inch and a half to the end of the shaft first. bored about a half inch hole
Let things cool down then had a go with the make shift puller with zero luck
So then we really got stuck in and gutted it as much as we dared without destroying the hub then yes left enough good stuff to weld another nut on and pulled it out
