Hi i have a 259d with an electronic engine that it's throwing a speed engine position sensor alarm I changed the sensor and it's still does it, what should the signal look like if I hook onto it with a scope to check it at the sensor and at the ECU
Only known good wave forms library I know would be https://www.aeswave.com
Is the skipping random or regular? Problem might be mechanical, like improper gap or mechanical damage to a teeth.This machine only has 500 hrs and looks like new around the engine I tested the resistor and it tests the proper resistance last night I hook my scope on to the signal wire and I found that it's skipping pulses do you think I should cut the wires and change the plug I once had to do that on another skid steerView attachment 226836
I was checking the signal just behind the plug with a pin probe that stabs through the rubber of wire so that's probably what you would call under load?
I'm not exactly sure how it can not connect but I have tested two sensors now and with not coming a steady pulse to the wire right behind the plug I think that's the only thing it could be but maybe I'm just missing something yet
Did you try the testing procedure in Post #6 above.?
If so what was the result.?
Another suggestion. Find every major/minor harness connector between the sensor and the ECM. They will be shown on the electrical schematic. Open up each connector in turn and do the "wire pull test" on every wire in the speed sensor circuit. It won't be the first time to find a connector where the pin/socket has not been pushed in far enough to lock correctly. IMO doing the basics is what needs to be carried out before starting to get into the more esoteric stuff like putting a scope on the sensor signal.
