The original is a 3406B with a mechanical fuel system which, to be frank, is why I'm struggling to see the logic in repowering with an electronic engine instead of rebuilding the original. But JDOFMEMI has clearly been around the block a few times so I'm going with the flow and helping out as best I can.
Cmark, Nige, and others
First, many thanks for the help. It is greatly appreciated.
After troubleshooting, it seems the original engine suffered from a failed fuel injection line under the valve cover. This diluted the oil rapidly, and set off the low oil pressure alarm. By the time my operator got it shut down, it had a rod hanging outside of a rather large hole in the block. It is well beyond rebuildable.
The E model engine was available for a reasonable trade, and here in the Republic of Kalifornia, we are under CARB regulations requiring the cleaning up of the fleet. While the donor engine is not the latest and greatest, it is a strong step up in the emissions department, so I will receive credit for that. It will take some work, but I have a competent man on it, and we have done several swaps like this before.
Today we have verified that we can physically make everything work. We have to do some work on the fan drive mount, and an alternator and AC compressor bracket will have to be made from scratch. All other items will function as is with a few changes. The oil pan and pick up from the original will be used, the pump drive bolts right on, and even the exhaust and muffler will work. Aftercooler piping will work using a mix of old and new piping. There are other differences, but we are thinking they will not cause problems. After we run it, that thinking may change, but for now it looks good. The electronic engine MAY even save fuel, or not, since it is higher horsepower.
Based on past experience with truck engines in an excavator, while it is not perfect, it is much more economical for a machine near the end of its useful life. We can do this and hope for a few more years from it, and it will be well worth the work. I know that the torque curves are different for these two engines. The truck engine is designed to run at near 1500 rpm, +/- 200, for peak performance. That is where the peak torque is available at, and it falls off in the upper RPM range.
The excavator on the other hand is designed to run 2,000 RPM all day long, and I suspect the peak torque is in the 1800 to 1900 RPM range. I would like to see a torque curve for the two engines to compare, if anyone knows how to get that information.
What I am hoping for is that the increased power of the truck engine makes up for the different RPM range for the peak torque. If that is the case, it will have no problem holding RPM when the pumps load the engine. If not, it will still work, but RPM could drop, leading to reduced performance and longer cycle times. I can live with that as long as it is not excessive.
If we do all this and it does not work out, I will have a rebuilt engine to put into one of my road trucks, but I am confident we will make it work. The ECM thread should be helpful for sorting out the issues there, and that will allow us to keep all of the machine electronics as is.
I will fill you guys in as we progress.
Thanks again for the help.
