So much for my good luck. I have a Miller Big 40 welder with a Continental F163 engine I got for cheap a few years ago from a trailer shop that rarely used it. The trailer shop wanted to rent/borrow it for a small job so I got it running and welding great. I burned a couple rods and made sure everything worked properly. Went to pick it up Monday and made sure it started right up. Trailer shop tried it out before they headed out and everything was good. Got to the job and it worked great at first but then had no weld output. They called me and had tried everything I could think of. I drove to their shop and they brought the welder back. It had started to rain a bit anyway. We started the welder and saw it had no arc but also would only run on full choke. One of the hoses on an inline fuel filter had come loose and/or cracked. Not enough to drip but loose enough you could turn the hose. Couldn't tighten the clamp anymore. I read online that that can cause a lean condition and require full choke to compensate. Just wondering if anyone on here has had a similar issue or could confirm a loose fuel hose could cause an engine to need full choke to run? I'm going to take it to a welder repair shop but hoping I can fix the engine issue myself and save a little money.
