heymccall
How would you go about fixing these holes?
8k axles with equalizer.
Obviously, a new equalizer is in order. But, it calls for a 7/8" bolt and the holes are over 1" egged.
If it weren't for the deck tilt sharing the equalizer bolt, I'd just weld in stepped washers.
The tilt cylinder pin is seized in the rod, making more work to simply lift off the deck, and I'd like to avoid flipping it over if possible.
Is there a simple way to just weld/ bore the holes?
I'm open to suggestions, as the axle is 2 weeks out.
