(E55 Bobcat) New fan belt tore apart after 20 hours of use.....any ideas as to why?
rdavison39
Toronto, Canada
Electrical Engineer, self employed
So I just installed a new fan belt on my e55. I've been running the machine for about 20 hours just fine and however the belt broke again. I thought the first belt broke just because of age or wear and tear (its been on for at least a couple hundred hours) but now I'm thinking its something else given the brand new 2nd belt ripped apart after only 20 hours of use. If it matter any, the first belt had a clean rip. The 2nd belt was shredded. The fly wheel also has the air condition belt for the compressor on it so I'm thinking the fly wheel is fine. The wheel on the alternator seemed solid. I couldn't see very well the 3rd wheel and not sure what it even drives.
Anyway - if people have some strategies to figure out why this happened that would be great (or what to look at or to check). In the meantime I guess I'll install a new belt so see if it was just an anomaly or if something else is at play
Thx
Ron
JD955SC
The South
Check each pulley and idler. Make sure the tensioner is applying appropriate tension. Makes me wonder if something is worn and pulley is slipping out of alignment. Also make sure the belt is routed correctly. Sometimes that’s tricky.
rdavison39
Toronto, Canada
Thanks for the tip JD - That belt, however, is a "pry on" belt - i.e. there is no tensioner. What do you mean to make sure the belt is routed correctly ? There are no grooves or anything on the belt...although there are grooves on the pulley wheels....
thanks in advance
Ron
Tinkerer
thanks in advance
Ron
I never heard of a pry-on belt.
The belt tension is controlled by either a spring loaded tensioner or by adjusting the alternator position.
If your E55 does not have a tensioner then you need to get the factory specs for the belt tension and set it to that.
A new belt will fail quite soon if the tension is too high.
JD955SC
The South
I have…but this is a first for me to hear of it in equipment. It’s a cheap crappy throw away econobox car “innovation”.
mks
Southwest Cook County Illinois
None currently
Stretch (sansa)? Belt.
Lisle and others make a tool for install.
Some BMW engines have them
When they fail they can turn into a very long spaghetti like string.
Wraps around crank pulley and sometimes gets pushed through the crank seal. Big leak then.
If enough gets through can be found in oil pump pick screen.
Flat belt on grooved pulleys seems like a possible problem.
Coaldust
North of the 60
I’m guessing you got over-zealous with the pry bar and damaged the belt during the install. I wonder if a stretch-fit install tool like what Subaru or Gates sells would work better than a pry bar? 0D18CE07-1A6D-4C68-BD2B-102025D7BBFA.jpeg
rdavison39
Toronto, Canada
When I get back to the machine later this week I will try and remove the belt and take some pictures. The new belt is torn to shreds so not sure what is left but engine was too hot to reach down and grab anything and I had to leave. It was identical to the previous belt which just snapped a few week ago. I have the same instructions that Coaldust posted in my service manual that say to use a pry bar I actually was able to feed on the flywheel by hands while turning the engine with a pry bar - wasn't easy but I did not want to damage the belt with a pry bar.
So i guess i was wrong about the fan belt not having ribs as the description of the belt on the website says it does it has ribs. ( https://shop.bobcat.com/ca/7010894-fan-belt.). I did buy an OEM belt from a Bobcat dealer. He also mentioned that the belt was a "pry on" belt (he may have used a different term) and that my system did not use a tensioner. The manual also does not mention anything about a tensioner or to adjust the tension
I sure hope the shredded belt did not push the bearing seal as MKS mentioned - it did turn into a spaghetti type of mess.
I was able to visually inspect the wheel on the alternator (looked fine) but not the water pump. It doesn't look easy to get to.....damn!
By all accounts it would appear I have to examine the wheel on the alternator and wheel on the water pump. Doesn't seem like there can be any other culprit.
Pony
SE Queensland
I've installed those belts on Subaru vehicles and the new belts come with a plastic "slide" tool, along with a plastic "pry bar", install was easy, I'm surprised your belts don't come with same.
But I got nothing re your current problem.
I suppose it's not impossible that you got a faulty belt for your 20hr one.
rdavison39
Toronto, Canada
I suppose the water pump or alternator could be seized.
So probably silly question - but if the water pump or alternator were seized then the wheel that the belt runs on would not turn, correct?
I couldn't get my hands in their because engine was so damn hot and then I had to leave the job site and not back until Friday......
Coaldust
North of the 60
Well, yes. Thus, destroying the belt in short order. More likely, one rib of the belt was hanging over a pulley and eventually shredded it. Its an easy mistake to make in a tight engine compartment.
rdavison39
Toronto, Canada
Thanks Coaldust. When I picked up the new belt at the dealer yesterday I talked to one of the mechanics and that's exactly what he said. and I have to say I never checked if the belt was completely over the water pump wheel...it's very hard to get a good look at but rest assured this time I will! I'll update thread once it's back on and I have run the machine for >20 hours
mks
None currently
It was fairly obvious in the above case The front of the engine and main serpentine belt were covered in oil. The failed stretchy belt was for ac compressor only.
I unwound the string from the crank pulley and it stopped so I removed the crank pulley and then pulled the rest from the crankcase.
In this case it’s recommended to pull the pan to check the sump screen because trouble codes indicate variable valve control problems.
rdavison39
Toronto, Canada
Okay - i put the new belt on today after untangling the previous belt (see pic). The new belt went on fine just like the previous "new" belt. I have run the belt for 6 hours today. I have some pics before I ran, while running (could not upload the video) and after 6 hours.
I did check the wheel on the alternator and it turned true and had no play. Same with wheel on the fan.
Its possible that the belt was not on one of the wheels properly but I highly doubt it. I will just keep checking and hopefully surpass the 20hr mark I did before. Maybe I (hopefully) had a defective belt.
The tangled mess of last belt. The one before this belt had been on for over 200 hours and was a clean snap
Pic above showing belt on the fan (flywheel)
Picture below - belt at end of day
Anyway, I hope I am not back at this forum in the next couple of days because that means the 2nd new belt had a problem.....
Thanks everyone for their insight and tips
ahart
Indiana
If the belt in the last pic that says “stretch” on it is the one you just put on, you have an alignment issue somewhere. You can see bad wear on the inside edge of the belt already.
Reading back through it looks as if the inside belt is the one you’ve changed. Either way, something looks amiss about the belt marked stretch fit.
