Dump truck build?
Currently looking to upgrade trucks, my old 88 Mack single axle is on its last leg, and impossible to find parts for.
I've been looking for mid 90's tandem trucks.
I don't think I need a tri axle for what I do. Mostly septics, we have a good hauling company here and can beat up their trucks. I need it to haul equipment around and occasional load of sand
In Mi here we can only gross 48k in a tandem dump, 57 in a tri.
I found a 92 l9000 , 3406 425hp engine, 13 speed. Jake, lockers, clean truck, needs paint. 16k front with 385 tires. 40 rears, walking beam rear.
However the truck is a tractor only, guy also has a 13' bed for it, and air operators exchanged pto, I would need valves, and a few little things and attach the box to the truck. And build a rear hitch plate. And paint the box and truck.
Everything else I have been finding is 12k fronts with little tires, and 300hp 10 speed trucks. Which I do not think would work great for a truck.
Here is the truck and box
Like I said needs paint, and work to attached, for how the tractor is speced, seems like would be everything I want in a dump. I'm not looking for a 16-18' tri axle long truck. I do tighter jobs and a truck that is a little shorter would work best for me and I can still haul 13 ton on it which would be about my legal max here.
Any thoughts or I'm crazy?
Thanks
Thanks
