duetz F2L 1011
Browfurrow83
Ontario
Trying to do a timing belt on a BW-120 AD-2 and I cannot find the camshaft lock pin hole. It should be near the oil filter on the back left hand of the engine, but I can't see anything there. there is not much room for my head between the 2 halves of the machine.
mg2361
Pennsylvania
Equipment Mechanic
Welcome to HEF Browfurrow;)!
The cam pin hole should be next to the engine oil filter, IIRC. Hopefully someone with more thorough knowledge of this engine will chime in.
Browfurrow83
Ontario
I am seeing something different, the oil filter points down and I don't see either of the plugs shown in the image
Browfurrow83
Ontario
I found one above the fuel rack that looks like it could point to the camshaftthere is a hole through the rack but it doesn't line up. The holes are also slots and don't line up.
Browfurrow83
Ontario
Also once I find it this pto belt will be in the way, does the gold pulley just slide off?
