Cboyd43
Good afternoon, I have a gehl that has a duetz 1011f motor 3cylinder. I have an issue with it as it is blowing white or white/gray smoke and also has a miss in it. The return lines going into the injectors had many leaks and have since replaced them, I also put new injectors and put a new valve cover gasket in. I did reset a couple of the valves. Still blowing smoke. At a loss right now. I am a little novice on this so any insight/help appreciated. It also does seem to have fuel in the oil but read that leaks could cause that.
