mpirate
Hi guys. I've got a stupid question for any of you. I have a bobcat 863 that sheared the teeth off of the timing belt. I bought all of the necessary parts and tools (pushrods as well) and am replacing them. The tension gauge that I bought (draf industries), either isn't calibrated properly, is damaged or inaccurate, or, I'm just not using it correctly. When I tighten the belt, the best that I can get the gauge to read is 40lbs, which is way too low on the gauge, while the belt itself is VERY tight.
Too tight, in my opinion. I have replaced quite a few timing belts in my day, just never on this engine or machine. Here is my stupid question: Can I just tighten the belt to what I determine is fairly tight by hand, or is the exact tension in ft/lbs absolutely required? I'd rather not shell out another $100 for a gauge that might be correct this time. Thanks!!
