drive probleme cat 315L
bruce1
asheville nc
1996 cat 315L track when it gets hot the left track won't drive when it's cold it works fine .im just an amature shade tree mechanic trying to help a struggeling small one man operation keep going so i may be on here alot asking questions any help would surely be appreciated thank you
Jam
Cork, Ireland
Building contractor
Swing manifold would be worth a look first. If you open off the case drain port behind the boom foot and track the machine see does it pressurise the circuit. Had to replace seals on my 312 a fornight ago made a big difference to track power
06Pete
MD
I just had a 315 b with a weak track and it was low piolot pressure on that side. Just adjusted the set screw on that pedle and now it walks straight. 1/2 turn was difference of 250 psi to 500 psi.
