BAD5oh
Same machine that is split for center pins in another thread. 1988 Dresser 520B 3 spd trans. Cannot find a tag on the trans. Was rebuilt around 5k hrs by previous owner just before we purchased. Now has 7400 hrs
I drained the trans oil and then removed the strainer. Found bronze metal shavings in it. I crawled under and stuck my hand in the strainer hole and pulled out everything seen on the rag in the pic. Need to know what they are and if I should start pulling the trans while the loader is apart and luckily split so I have more room
Weird thing is trans works fine with no problems and is never making noises or overheating. Travels through all gears just fine.
Any thoughts?
Any thoughts?
