Oerthedge21
Recently picked up an early 510B loader. From what I can tell someone blew a rod thru the block on the original engine and repowered with a 4bt Cummins like the later machines. Runs great, all hydros work fine, but suddenly it's started pissing trans oil out of the drain on the bellhousing. Gets worse when you put it in gear and move. Just sitting in place running it's a solid dribble. With the drain plug installed it leaks all around the housing and out the starter instead. Can't find mich info on whether these are wet or dry bellhousing machines. And even still, the hydraulic pump drive gearbox sits between the transmission and the engine. We'd thought it to be a leaking hyd pump at first but after running for 5 minutes and blowing out a good half gallon of fluid the hyd tank hasnt gotten any lower, plus the oil leaking out is darker than the hyd oil. Also isn't a bad rear main seal, engine oil hasn't dropped a bit and it smells different. Damn near positive it's a trans oil leak, unless there's more fluid in that area somewhere that I'm not aware of. Anyone has a similar issue, or have a breakdown of that area? The manual is over 100$ and if I can get by on this one without having to order that and wait weeks to get it that would be great, need this thing in usable shape as soon as possible
