Dozer pulled pans
Discussion in 'Scrapers' started by Jeffksf, Oct 25, 2008.
  1. Jeffksf
    Jeffksf Well-Known Member
    Oct 25, 2008
    62
    Mouse operator
    Cleveland, OH.
    This was in Plainfield IL. last year. D8 tractors pulling pans (1 JD)
    Any input on why or when you would run dozers instead of a Cat challenger type setup over these?
    The company (Ryan) seems to be a pretty big outfit in the midwest
    http://http://www.ryancentral.com/photo.html
  2. Deere9670
    Deere9670 Senior Member
    Feb 23, 2008
    387
    Farm equipment operator
    Illinois
    Hi jeff, were you from IL or somthing? Plainfield is right next to were I live, and yes Ryan is a large outfit, but all of there iron is sitting now, collecting rust. From what ive seen on the i355 tollway extension, that ran through my back yard, tjl would use the ag tractor pans for stripping loose topsoil, and then bring in d9 and d10 s with the big dolly wheel pans for cutting out the clay. By the way it was cool to wacth, because tjl would hook three of those pans behind a challenger!
  3. Jeffksf
    Oct 25, 2008
    62
    Mouse operator
    Cleveland, OH.
    I was visiting my in-laws.
  4. DPete
    DPete Senior Member
    Feb 22, 2007
    1,677
    Central Ca.
    Challengers are farm tractors, I doubt they would do the job being push loaded and getting around with that wet material, just not heavy duty enough. Those are nice looking machines
  5. DPete
    DPete Senior Member
    Feb 22, 2007
    1,677
    Central Ca.
    This scraper is 20 yds level 27 heaped
  6. Turbo21835
    Turbo21835 Senior Member
    Oct 20, 2007
    1,135
    Road Dog
    Seems to Ryan does a lot of work with short runs and a lot of elevation change. Any time they work in this area they seem to do landfill work. Which is some major uphill climb. It would be rather difficult to do with scrapers, or even trucks.
  7. surfer-joe
    surfer-joe Senior Member
    Mar 25, 2007
    1,403
    Arizona
    Challengers are limited in their capacity to tow and load pull scrapers by their traction, or lack of it. Their original design function was to avoid soil compaction. They do alright with smaller pans, but these bigger pans (25-35 yds) require a heavier tractor with much more tractive ability. This is especially so in soils that can be slippery (clay or loam, top soil) or in rocky or hard gravel. I'm sure DPete has had all kinds of experience with his in these situations. Even D9's have trouble loading pull-pans in some cases where it's wet or very soft, or in very hard materials. But then, all scrapers do.
    I guess that crawler tractors and pull scrapers ink out in some situations, but I'm not sure that double-barrels would not do as well or better. I know I've been involved in estimating situations looking either way, and even if the costs were tilted better towards cats and pans, the long term efficiency and capabilities of the rubber-tired machines penciled out better. Cats and pans are not an off the shelf rental item either. Those firms that use them usually already have some in inventory. Somehow, they make it work.
  8. WabcoMan
    WabcoMan Senior Member
    Apr 16, 2008
    258
    Heavy equipment parts manager
    New Zealand
    Once upon a time track type tractor & towed scraper was the only way to move dirt.
    There is still a place for the track type tractor & towed scraper where:
    A. traction is poor and the hauls are short
    B. material is unsuitable and you need to spread it in thin lifts to dry out before compaction
    C. material is heavy (wet clay, peat etc) and underfoot conditions are soft.
    In these scenarios a track type rig will run rings around a wheel type rig with a pan or a motor scraper:pointhead
  9. trackfanatic
    trackfanatic Well-Known Member
    Jul 17, 2008
    46
    been there done that
    Having helped dig a dozen or so 40k yard dams with a 12 yard scoop on the back of a D68u, and owning a little old cable Le Turnover I know just how bloody slow and inefficient they are compared to having wheels under you.
    Having said that they're a hell of a lot faster than digging a dam with a blade. And we don't work in the wet, we go home and spend 4 months pulling the gear down ready for next dry.
    Think I'll stick with me 621's thanks.
  10. Greg
    Greg Senior Member
    Jan 28, 2008
    1,175
    Excavating Contractor
    Wi
    Hook the pans up here anytime have to move any quantity. Pan behind a Cat is so much quicker than trying to push. Blades off of my D7 & D8 and pans hooked up 90% of the time here.
  11. fiat41b
    fiat41b Senior Member
    Jul 15, 2008
    323
    pawnee il.
    dozers and pans
    right now im looking for at a 463 to pull behind my d8k i have removed the kelly ripper and was wondering if i will be able to use the factory hand control and valves which has the same control as my blade up down left to right.
    The 463 has a cable on the apron which has no down pressure can one tie into the hydraulics so that you can have up-down and raise apron all the way up and then eject letting reverse action being the ejector to return first and then apron to follow allowing you to raise or control the apron for the next cut or will i need so kind of 3rd control i own a couple older double barrels but this would be my first crawler pan. thanks
  12. Renfroe Grading
    Renfroe Grading Well-Known Member
    Dec 15, 2007
    50
    Gainesville, Ga
    Get a sequencing valve thats what we did on our 621 conversion and use the ripper valves.
  13. Renfroe Grading
    Dec 15, 2007
    50
    Gainesville, Ga
    I also have a complete pilot control system for a D8k and a complete rome scraper I would sell.
  14. fiat41b
    Jul 15, 2008
    323
    pawnee il.
    dozer pan
    Well i was telephoned today that someone from Iowa is going to go ahead and buy the 463 i was looking at they have been holding the thing for him for a good while and i just kept checking back every now and then over the last few months on it,thinking the guy might of backed out its the one on machinerytrader for 17,500 located in Peoria guess im out of luck that one was close to home mr renfro how big is your rome and how much are you asking wish you were closer,
  15. 9420pullpan
    9420pullpan Senior Member
    May 5, 2005
    1,162
    Central PA
  16. Greg
    Greg Senior Member
    Jan 28, 2008
    1,175
    Wi
    tough time using the blade joy stick cause you need three functions. Endgate open and close, pan up and down and ejector in and out. Need third valve.
  17. 9420pullpan
    May 5, 2005
    1,162
    Central PA
    it is controlled by the ripper control, and for the apron and ejector they use a diverter valve mounted on the bowl.... once the apron is open all the way the ejector pushes material out.
  18. Construct'O
    Construct'O Senior Member
    Feb 19, 2007
    928
    Dozerwork,tiling plus many more!!!!!!!
    SW Iowa
    That is the way my D6H is set up,using the ripper valve and the Ashland scraper has diverter valve.:usa
  19. fiat41b
    Jul 15, 2008
    323
    pawnee il.
    I did check out the ashland 175 and even talked to a rep from ashland thought about renting one for a try out i was told that the come with the sequence valve if ordered that way which would work for my up-down-left to right ripper control.
  20. Renfroe Grading
    Dec 15, 2007
    50
    Gainesville, Ga
    I would have to have 30k out of the Rome scraper with the pilot control valves for a D8k.
    The Scraper is 28yds and is not a conversion it was built as a hydraulic scraper.
